Windows Store Version - error opening AUP projects
jademan
Forum Crew
Re: Windows Store Version - error opening AUP projects
Post by jademan » Fri Dec 25, 2020 12:31 pm
ruchi1 wrote:
Fri Dec 25, 2020 9:44 am
"This file was saved using Audiotonic 2.1.0.0.
Yes, For the complete instructions, see here: viewtopic.php?f=46&t=114374
