Help with reducing 2 loud SCUFF sounds on a recording for a Christmas Gift
superCWdad
Post by superCWdad » Wed Dec 23, 2020 7:46 am
Hello and let me first start off by thanking anyone who reads this and for anyone that can provide me some insight.
I have a short file of my son singing Frosty the Snowman I am putting into a Christmas project for the grandparents and there are two sections where I scuffed the microphone on my cellphone and it is jarringly loud. The first noise is at 4 seconds and the second is at 13.5 seconds.
I was looking for some technical know how on the process of reducing the overall amplitude of the noise hopefully without the need to diminish or destroy the vocal portion of my son singing. I have included the two sections here, the whole file is 5.10 Mb and I could not upload the whole file here, if someone would be willing to provide the know how I would appreciate it.
Thank you so much and have a wonderful holiday!
Frosty Song Scuff Snip.wav
(155.7 KiB) Downloaded 12 times
waxcylinder
Re: Help with reducing 2 loud SCUFF sounds on a recording for a Christmas Gift
Post by waxcylinder » Wed Dec 23, 2020 11:11 am
I used Multi-vie for combined Spectogram and waveform view (you can select that by clicking in the track name toi get the track's dropdown menu)
The bright red shows clearly the extent of the scuff - so I selected that and then used Ctrl+K to delete that section
Scuff deleted.png (116.95 KiB) Viewed 116 times
I then zoomed in a long way and observed a small disjoint where the two sides of the waveform did not match entirely (will cause a click)
Scuff deleted disjoin.png (41.24 KiB) Viewed 116 times
I then selected a few samplesaround that area and used Effect > Repair
Scuff deleted disjoint repaired.png (39.44 KiB) Viewed 116 times
And now it sounds like this:
Peter
Frosty Song Scuff Snip - repaired.wav
(127.42 KiB) Downloaded 11 times
superCWdad
Post by superCWdad » Wed Dec 23, 2020 3:28 pm
@Waxcylinder
Thank you very much for this tutorial, I successfully followed your detailed post and fixed both scuffs in the audio and it sounds great!
I really appreciate your time and knowledge you gave to me and anyone else who may have a similar issue they would like fixed.
Have a great holiday season and Love to you and your family.
waxcylinder
Post by waxcylinder » Wed Dec 23, 2020 3:54 pm
Really glad it worked for you - have a great Christmas
Peter (AKA Waxcylinder)
