Track Markers in wave files
mikezz1
Operating System: Windows 7
Post by mikezz1 » Wed Dec 23, 2020 1:41 am
Windows 7 Pro sp1 32bit
I have a long recording done in Creative Wave Studio 7 that I added markers to so I can skip to the next track on an audio cd or on my phone/player, etc. Can Audacity read these makers when opening the wave file? Supposedly they are saved in the metadata but I'm not sure if it is a standard among different wave editors.
My original intent was to mark the tracks and make a cue sheet to import into CDBurnerXP to make an audio cd but it's too large for one cd. I read that Audacity can split wave files so I downloaded it thinking it might be easier to put markers in the file for the tracks and then split them. This way I could burn cds or import to a phone or player only the tracks i want hopefully with track names derived from the markers.
I searched the faq and help for markers but didn't find anything related to tracks.
DVDdoug
Forum Crew
Re: Track Markers in wave files
Post by DVDdoug » Wed Dec 23, 2020 2:29 am
You can use markers (labels) in an "Audacity Project" but as far as I know they are not compatible with anything else. And, they are not included in your exported audio file(s).
As you know CDs, DVDs, and Blu-Ray's all support tracks/chapters. But "computer file formats" either don't support tracks/chapters and/or most player software doesn't support them. There may be work-arounds with a player that supports cue sheets or Matroska MKA files might support tracks but these solutions are non-standard.
Another issue is that a file can have only one title-tag.
If you buy an MP3 album from Amazon or an AAC album from iTunes you get a separate file for each song. Your player software can play the songs from an album in track-number order or in random order, etc. And most player software supports playlists if you just want to play some of the songs and/or a mix of songs from different albums, etc.
Players use the metadata tags to make a database so you can do almost anything as far as selecting & sorting tracks.
I don't know anything about Creative Wave Studio. Audacity has a metadata editor but it "gets complicated" because different audio formats use different metadata formats. And, Audacity's metadata editor doesn't support album artwork.
WAV files can be a problem because metadata is not well-standardized or well-supported for WAV. Most other formats are better (for metadata) and if you want lossless FLAC (which uses Vorbis tags) is usually a better option. Plus, your files will be about half the size.
For general-purpose metadata editing I use MP3Tag. It supports all of the standard file formats... It's not just for MP3/ID3.
mikezz1
Post by mikezz1 » Wed Dec 23, 2020 4:04 am
Will an 'Audacity Project' be an index of the original wave file kind of like when you use Adobe Premier for a video project it doesn't contain a copy of the original data, just a pointer to it or does an Audacity Project save it as a second wave file leaving the original wave recording intact?
It sounds like the labels will accomplish what I need to do to prepare for splitting into sequential songs. I'm just a little confused about how the first track gets named when you place the labels between songs. Whether I export to a format to burn an audio CD or separate MP3 files for a player I'd like it to play sequentially without gaps between the tracks.
Thanks for the help.
DVDdoug
Forum Crew
Post by DVDdoug » Wed Dec 23, 2020 5:05 am
An Auldacity Project has it's own copy of the audio in many-many small files. It's only useful within Audacity. Your original files are not touched unless export and overwrite them.
BTW - If you are recording (so you don't have an "original" copy) it's a good idea to export to WAV so you'll have an "original", whether you make a project or not. Because a project contains many small files it's more easily messed-up, especially if you move or share the project.
If you're making a CD you can make one big WAV file and set the track markers with a cue sheet. I've done that several times with "live" recordings and a few times with crossfaded tracks. Getting gapless playback with MP3s can be "iffy". I think most other formats are OK.
You can put a label at time-zero.
