Audacity and Windows Task Scheduler
Re: Audacity and Windows Task Scheduler
Post by steve » Tue Dec 29, 2020 7:54 pm
sebalorek wrote:
Tue Dec 29, 2020 7:43 pm
I'm using version 2.3.3
Perhaps worth trying the current 2.4.2 version https://www.audacityteam.org/download/windows/
sebalorek
Operating System: Windows 7
Post by sebalorek » Tue Dec 29, 2020 8:49 pm
I will try. It is a pity that Audacity does not have such an additional option to start recording when the program is turned on :-) But I know that my case is quite specific ...
