Audacity and Windows Task Scheduler
sebalorek
Operating System: Windows 7
Post by sebalorek » Mon Dec 21, 2020 11:03 am
In the Windows Task Scheduler, I can run Audacity at 3:48 and then at 3:50, automatically starting Python recording.
However, sometimes there is an error in the task schedule. Or the Audacity.ece application freezes, it is usually described in the schedule as error 0xFFFFF. Then the automatic recording doesn't start either and I have to manually stop the program and restart manually. Today, for example, it supposedly started automatically, started recording, but after a while it also crashed and recording stopped, I only noticed it after a few hours.
Sometimes it also happened that the application opened automatically without errors, but the 0x1 error caused Python to be automatically recorded.
Is the problem with Audacity or with my system? Does anyone know how to deal with this topic?
I will add that often everything starts correctly, these errors occur from time to time.
Hope the translation is quite correct and understandable :)
Re: Audacity and Windows Task Scheduler
Post by steve » Mon Dec 21, 2020 12:29 pm
Have I got this right?
1. You are launching Audacity from the Windows Task Scheduler
2. Then you run a Python command from the Windows Task Scheduler to send a command to Audacity via mod-script-pipe to start recording?
3. Sometimes this works but sometimes it fails.
What are the exact commands?
How do you ensure that the Python command comes after Audacity has fully started?
sebalorek
Post by sebalorek » Mon Dec 21, 2020 12:40 pm
1. yes
2. yes
3. yes
The python.py file is written like this, I am pasting it below. It usually works. It happens, however, that it will not start, for which, I do not know.
And the crash of the application itself at startup is a different problem.
Code: Select all
import of os
import sys
if sys.platform == 'win32':
    print ("pipe-test.py, running on windows")
    TONAME = '\\\\. \\ pipe \\ ToSrvPipe'
    FROMNAME = '\\\\. \\ pipe \\ FromSrvPipe'
    EOL = '\ r \ n \ 0'
else:
    print ("pipe-test.py, running on linux or mac")
    TONAME = '/tmp/audacity_script_pipe.to.' + str (os.getuid ())
    FROMNAME = '/tmp/audacity_script_pipe.from.' + str (os.getuid ())
    EOL = '\ n'
print ("Write to \" "+ TONAME +" \ "")
if not os.path.exists (TONAME):
    print ("..does not exist. Ensure Audacity is running with mod-script-pipe.")
    sys.exit ()
print ("Read from \" "+ FROMNAME +" \ "")
if not os.path.exists (FROMNAME):
    sys.exit ()
print ("- Both pipes exist. Good.")
TOFILE = open (TONAME, 'w')
print ("- File to write to has been opened")
FROMFILE = open (FROMNAME, 'rt')
print ("- File to read from has now been opened too \ r \ n")
def send_command (command):
    "" "Send a single command." ""
    print ("Send: >>> \ n" + command)
    TOFILE.write (command + EOL)
    TOFILE.flush ()
def get_response ():
    "" "Return the command response." ""
    result = ''
    line = ''
    while line! = '\ n':
        result + = line
        line = FROMFILE.readline ()
        #print ("I read line: [" + line + "]")
    return result
def do_command (command):
    "" "Send one command, and return the response." ""
    response = get_response ()
    print ("Rcvd: <<< \ n" + response)
    return response
def run ():
    do_command ("Record1stChoice:")
run()
Reason: code tags added
Post by steve » Mon Dec 21, 2020 1:28 pm
Perhaps a problem with copy / paste to the forum, but there appear to be some errors in that script:
Code: Select all
should probably be
Code: Select all
print ("Write to \" "+ TONAME +" \"")
Code: Select all
should probably be
Code: Select all
print ("Read from \" "+ FROMNAME +" \"")
(though both of the above could simply be commented out)
Your code is not exception safe. If anything fails, the script just carries on, ignoring the error, until it crashes.
At the very least you should check that both pipes exist, and check that Audacity is running before trying to send the command. Try to catch errors and exit with a meaningful error on failure. The classic Python way to handle errors is "Try / Except".
See:
https://www.w3schools.com/python/python_try_except.asp
and
https://realpython.com/python-exceptions/
jademan
Forum Crew
Post by jademan » Mon Dec 21, 2020 2:15 pm
In the Windows Task Scheduler, I can run Audacity at 3:48 and then at 3:50...
So you have two minutes; have you considered doubling the time ?
sebalorek
Post by sebalorek » Mon Dec 21, 2020 2:35 pm
I can, but I doubt it will change anything. With normal operation, the program starts in a second and is basically ready to run. And here are 2 minutes from starting the program to the start of recording. I have never encountered a crash of Audacity when I run it manually from the desktop.
jademan
Forum Crew
Post by jademan » Mon Dec 21, 2020 2:58 pm
See:
and
What steve said. :D
sebalorek
Post by sebalorek » Tue Dec 29, 2020 5:51 pm
This is an error that i'm getting after script is opened by task scheduler. It seems like it cannot open the pipe for some reason.
Code: Select all
    FROMFILE = open(FROMNAME, 'rt')
FileNotFoundError: [Errno 2] No such file or directory: '\\\\.\\pipe\\FromSrvPipe'
but when I try manually open the script after the first error is appearing I get this one:
Code: Select all
Write to  "\\.\pipe\ToSrvPipe"
It happens time to time but mostly works as expected.
Post by steve » Tue Dec 29, 2020 7:10 pm
Perhaps you need to put in a short delay before
Code: Select all
That suggests some sort of timing issue.
sebalorek
Post by sebalorek » Tue Dec 29, 2020 7:43 pm
Can it be done somehow from Audacity? I would like to add that sometimes after unsuccessful start of recording, I run the script again and recording starts without any problems. But sometimes Audacity freezes.
I'm using version 2.3.3 - but I don't know if it matters in this situation.
