cursor disappears right of screen
rectek
Post by rectek » Fri Dec 18, 2020 4:20 pm
As usual, I suspect I have a simple fix problem but I cannot find solution after some frustration spent trying to fix this.
When recording, the cursor disappears off the right of the screen, instead of staying visible where I can see it advancing , as the music is recorded.
As always, thanks in advance for your answers, and Merry Xmas to all.
Felix
rectek
Re: cursor disappears right of screen
Post by rectek » Fri Dec 18, 2020 4:35 pm
oops- I forgot particulars - Win 10, newer HP laptop and latest version of Audacity
Post by steve » Fri Dec 18, 2020 4:51 pm
Perhaps you've enabled "pinned play head", or disabled "Update display while playing".
See here: https://manual.audacityteam.org/man/tim ... tml#pinned
Normally, "pinned playhead" should NOT be enabled / selected, and "Update display while playing" SHOULD be enabled / selected.
rectek
Post by rectek » Fri Dec 18, 2020 5:25 pm
YES ! That advice solves issue.
thanks
Felix
