Making it easy to compare audio from two different vinyl pressings?
thisisalloneword
I often want to know which vinyl pressing of the SAME song sounds best. Can I import the two sound files into Audacity, level match them and then alternate playing them every five seconds? I want to create a single file that has these properties, i.e level matched and alternates between the two sounds files every five seconds.
thisisalloneword
Re: Making it easy to compare audio from two different vinyl pressings?
Thing I figured it out. I imported both tracks then went to "Analyze -> Normalize". Next I changed the snap-to interval to seconds. This made it easy to select 5 seconds of alternate tracks to silence!
Can toggle at will whilst playing ...
or alternate at fixed intervals ... viewtopic.php?p=233319#p233319
