Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Trebor
- Operating System: Windows 8 or 8.1
Post
by Trebor » Wed Dec 16, 2020 1:00 pm
antoniu200 wrote: ↑Wed Dec 16, 2020 12:36 pm
... What I think is that the ends got cut off because, when editing, the track was at max digital volume. Then, they inserted that discentering (with infrasound) and, when the track got exported, that cut off the bottom ends that were clipping.
You could
generate an infrasound track (say 2Hz sine wave),
mix it with the vocal, then apply rectifier, so the clipping will fade in/out/in/out.
- add infrasound, then recitfy.gif (36.18 KiB) Viewed 50 times
(Personal I think I already nailed it
here, without adding infrasound, but I'm biased).
