Multitrack recording
Davethefiddler
Post by Davethefiddler » Thu Dec 10, 2020 11:51 am
I'm wanting to be able to record myself playing fiddle, guitar, mandolin, each on separate tracks.
I can record several tracks and hear them all. Unfortunately when I record the 2nd and subsequent tracks, I cannot hear the previous tracks at the time of recording. I have tried headphones and loudspeakers but I can never hear the previous recording when recording the next one.
Re: Multitrack recording
Post by steve » Thu Dec 10, 2020 11:57 am
What microphone are you using and how is it connected to your computer?
You may find this page of the manual helpful: https://manual.audacityteam.org/man/tut ... rdubs.html
Davethefiddler
Post by Davethefiddler » Thu Dec 10, 2020 12:44 pm
I'm using a condenser mic connected to the audio input on the front panel. It does pick up each separate track as I record, but at the time of recording, I cannot hear the tracks I have already recorded. When I play the recording, all tracks have recorded. Obviously when recording myself playing, I need to for example, hear the fiddle track to be able to add the next track, a guitar track.
Davethefiddler
Post by Davethefiddler » Thu Dec 10, 2020 12:55 pm
Solved it.
I found this in the manual :-
Confirm the following settings in the Transport menu:-
Overdub (on/off) is checked (Mine was unchecked, selecting it made the difference)
Software Playthrough (on/off) is not checked.
Thanks to anyone who was pondering this.
jademan
Forum Crew
Re: Multitrack recording [SOLVED]
Post by jademan » Sat Dec 12, 2020 12:19 am
Solved it.
Thanks for reporting back that you solved your problem. :D
