Can't apply any effect, Value not in range
udrakan
Operating System: Windows 7
Re: Can't apply any effect, Value not in range
Post by udrakan » Thu Dec 03, 2020 10:24 pm
Thanks for your help, but thats a little too much when I only want to edit a couple of files. Ill use something else and come back to Audacity after I upgrade to Win10
dang.mai
Post by dang.mai » Mon Jan 25, 2021 9:05 pm
Hi, I've been having the same problem. I also live in the Czech Republic. I have a Windows 10 and the error still occurs. I also tried to change the preferences to "local settings" in audacity, but the program still uses commas instead of decimals. It's truly infuriating.
jademan
Forum Crew
Post by jademan » Wed Jan 27, 2021 1:38 pm
steve wrote:
Thu Dec 03, 2020 11:29 am
I don't have Windows 7 (it is now obsolete), but I think the problem is that you have conflicting settings regarding what the decimal separator is. You need to go through the Windows settings and ensure that the decimal separator is either set as a comma in all places, or a dot in all places. Check that in the "Regional and Language Options" that the "locale" ("regional setting") is consistent with the number format settings.
So Windows keeps moving things around...
I think steve means:
Settings (or Control Panel) > Time/Clock/Language and Region > Region (Change date, time, or number formats) > (Region Formats) Additional Settings > Decimal Settings
Also, see this thread: https://superuser.com/questions/747250/ ... l-keyboard
