Adding a warped vinyl effect
fiacre
Post by fiacre » Fri Nov 27, 2020 8:21 am
Hello,
I search a vst for adding a warped effect.
Izotope Vinyl would do the job very well with the option "warp depth", but he doesn't work as he is a 64 bits plug-in.
Thanks for your help
Trebor
Re: Adding a warped vinyl effect
Post by Trebor » Fri Nov 27, 2020 8:40 am
alternatives include ...
Plektron vinylizer ... https://youtu.be/Bl9wgp9Q1Ss
Plektron devicer ... https://youtu.be/3GNGXXZeW_g?t=20
If you just want warp, no crackle, see ... viewtopic.php?p=150279#p150279
fiacre
Post by fiacre » Fri Nov 27, 2020 9:08 am
Thanks, that was quick !
I took the "devicer", it works !!
waxcylinder
Post by waxcylinder » Fri Nov 27, 2020 10:56 pm
I have a 32-bit vn of iZotope Vinyl :?
fiacre
Post by fiacre » Sat Nov 28, 2020 12:49 pm
This is interesting. Do you have a link to this version ?
Thanks
waxcylinder
Post by waxcylinder » Sat Nov 28, 2020 12:59 pm
I got mine from the iZotope site - but it was a long time ago.
And I note they have changed the GUI interface now - so possibly the new version is only 64-bit.
See: https://www.izotope.com/en/products/vinyl.html#specs
fiacre
Post by fiacre » Sat Nov 28, 2020 1:23 pm
Unfortunately, the latest version is 64 bit only.
What interest me is the "year" knob, (70s, 80s, 90s...)
Maybe you could send a package with the .dll from your configuration ?
fiacre
Post by fiacre » Sat Nov 28, 2020 1:43 pm
finally, i found out that izotope can provide you the 32 bits version if you contact them.
Thanks for the help
waxcylinder
Post by waxcylinder » Sat Nov 28, 2020 1:59 pm
Glad you got that sorted
fiacre
Post by fiacre » Sat Nov 28, 2020 4:15 pm
I downloaded the version Izotope gave me.
Unofrtunately I got the same error message as with the 64 bit version.
Maybe Izotope don't work with the lastest versions... :?
