Making Audio Captcha using audacity
AFJ
Post by AFJ » Sat Nov 21, 2020 11:50 am
Hello everyone, I have two folders. One of them contains A-Z and 0-9 audio clips of 1.5 seconds and in another folder I have different kinds of noises. I want to take 5 characters from first folder (randomly) and stitch them. Then randomly select a noise from the noise folder and add that to the already 5 characters audio that has been stitched. Can I do this using audacity?
Re: Making Audio Captcha using audacity
Post by steve » Sat Nov 21, 2020 12:02 pm
How many times will you need to do this? Once, twice, 10 times, 50000 times, more?
AFJ
Post by AFJ » Sat Nov 21, 2020 12:18 pm
I want this 1000 times first, then 5000 times and if needed then 10,000 times. I am making a dataset for training a neural network.
Post by steve » Sat Nov 21, 2020 12:35 pm
If you know Python, then probably your best option would be to automate Audacity with Python. See: https://manual.audacityteam.org/man/scripting.html
(Note that the scripting API is not yet frozen, so there may be changes in later versions of Audacity, though such changes are likely to be small).
Trebor
Post by Trebor » Sat Nov 21, 2020 3:16 pm
... I want to take 5 characters from first folder (randomly) and stitch them. Then randomly select a noise from the noise folder and add that to the already 5 characters audio that has been stitched ...
Maybe possible with SoX ... https://en.wikipedia.org/wiki/SoX
[stitch = concatenate ]
... if needed then 10,000 times. I am making a dataset for training a neural network.
unCaptcha-ing ?
AFJ
Post by AFJ » Tue Dec 01, 2020 1:13 pm
Yes, I am trying to break audio captcha for which I need a dataset and I am trying to make my own dataset.
