Audacity stopped recording after Win 10 update.
Emerogork
Re: Audacity stopped recording after Win 10 update.
Post by Emerogork » Sun Nov 15, 2020 7:25 am
host: WASAPI
Recording: Speakers loopback
Playback: Speakers
Ok, but how do I set these? Aside from Host, they are not options in my pull down menus.
Is it something in the Win10 audio setup?
Post by steve » Sun Nov 15, 2020 8:40 am
Post your "Audio device info" so that I can see what options your computer has.
("Help menu > Diagnostics > Audio device info", then click the "Save" button)
Emerogork
Post by Emerogork » Wed Nov 25, 2020 4:42 pm
Sorry for the delay, I am a natural born crastinator and have become very good at it.
The attached file from HP2 is what I found. I hope it makes more sense to you than it does for me.
I new twist is that after the latest windows "update" the settings for the working computer (HP1) had to be changed. That one is now working with : Windows Direct Sound, Primary Sound Capture device, and Speaker/headphone/Realtek High Definition Audio.
What caused the change I don't know. I guessed around until it worked. (-:
I have not been so lucky with the second computer (HP2).
HP1 deviceinfo.txt
(4.49 KiB) Downloaded 8 times
HP2 deviceinfo.txt
(5.16 KiB) Downloaded 10 times
Post by steve » Wed Nov 25, 2020 5:06 pm
Your device settings for HP2 look correct for recording sounds that are playing on your computer, but the device is set to work with a sample rate of 48000 Hz only. The default sample rate for Audacity is 44100 Hz, so that may be the problem.
Have a look in the Windows Sound control panel and see if it is possible to set the Realtek device to 44100 Hz in both the Recording AND Playback tabs.
