I'm using the current version of Audacity 2.4.2
I can record and playback fine, but the wave form/audio track is not moving with it, in both actions, making editing nearly impossible. All was fine till today....of course.
HELP
Shelly Raffle
[email protected]
Audio Track not moving with indicator/cursor.
Re: Audio Track not moving with indicator/cursor.
Either tick "auto-scroll if head unpinned" in Audacity preferences ...
https://manual.audacityteam.org/man/tra ... ences.html
or pin the playhead for scrolling ...
https://manual.audacityteam.org/man/tim ... tml#pinned
