basic editing: clip boundary question
Re: basic editing: clip boundary question
Post by steve » Wed Nov 11, 2020 6:10 pm
Try this. I think it shows what is happening:
1. Select a 10 second region.
2. "Ctrl + i" (split)
3. Select a 3 second region
4. "Ctrl + C" (Copy)
5. Double click the 10 second region created in step 2 (the 10 second region is selected)
6. "Ctrl + V" (paste)
Notice that the selected region is replaced, but the split lines remain in their original places.
If you want the split lines to move, do it this way:
6. "Del" (or "Ctrl + K") to delete the selected audio
7. "Ctrl + V" (paste)
babag
Post by babag » Wed Nov 11, 2020 6:43 pm
thanks, steve. that's what i was going to try next, deleting before pasting. just tried it and it does work. adds a step but it's a short macro so seems fine.
edit:
actually, though, it seems like i can get rid of the last two lines this way which makes it one line shorter. :-)
thanks again,
babag
