Won't Label 2nd Region Properly While Playing
jademan
Forum Crew
Post by jademan » Wed Nov 04, 2020 1:26 am
Windows 10; Audacity 2.4.2
I'm sure I'm doing something wrong, but when I try to select and label two regions while audacity is playing, something appears to go wrong.
To reproduce, generate 30 seconds of silence. Press the space bar to begin playing. Now, while the clip is playing, press the following characters in sequence: "[", "]", Ctrl-"B", "abc", then enter, then: "[", "]", Ctrl-"B", "def", then enter. What I am hoping for is to mark and label two regions, one labelled "abc", the second labelled "def".
Audacity creates the first label just fine. And the next "[" sets the next left boundary just fine, but the following "]" acts as though I had just typed Ctrl-"B" before it: it creates a point label at the point where the left boundary was set then treats the "]" as data for the label. (I never get to the Ctrl-"B" or the "def", etc.).
Re: Won't Label 2nd Region Properly While Playing
Post by steve » Wed Nov 04, 2020 10:16 am
Works fine for me with Audacity 2.4.2 on Xubuntu:
jademan
Forum Crew
Post by jademan » Wed Nov 04, 2020 1:09 pm
:( Works not so well for me with Audacity 2.4.2 on Widows 10 Version 1909 (OS Build 18363.1139):
2nd Region Label.PNG (10.55 KiB) Viewed 48 times
Post by steve » Wed Nov 04, 2020 1:30 pm
Works for me on Windows 10.
Perhaps worth resetting keyboard preferences (https://manual.audacityteam.org/man/key ... ences.html)
I'm using the "Full" set of defaults.
Post by steve » Wed Nov 04, 2020 1:36 pm
This looks like you pressed:
  1. [
  2. ]
  3. Ctrl+B
  4. abc
  5. Enter
  6. [
  7. Ctrl+B
  8. ]
  9. def
  10. Enter
(steps 7 and 8 the wrong way round)
jademan
Forum Crew
Post by jademan » Wed Nov 04, 2020 3:34 pm
:? Yes, That's exactly what it "looks like". So I am merrily watching the cursor march rightward across the screen, when I press "]" and voila, a point label suddenly and magically appears and a label is created with the single character "]".
See attached video. No - I only use Ctrl-B for the first label.
I tried resetting my keyboard preferences to default (standard) as well as default (full). No change in behavior.
No cigar. No joy. :(
Anyway thanks for taking the trouble to try to duplicate this on Windows 10. :D I don't see what else you can do? :(
Post by steve » Wed Nov 04, 2020 3:46 pm
Ah, I bet I know what it is. Check in "Preferences > Tracks Behaviors" and turn off "Type to create label".
jademan
Forum Crew
Re: Won't Label 2nd Region Properly While Playing [SOLVED]
Post by jademan » Wed Nov 04, 2020 6:42 pm
Thats It! :D Now, all I have to do is figure out why my Multi-Tool is popping up! :shock: But I'll save that for another day....
This problem is fixed! :D
