Mixing one kind of Noise in multiple audio tracks
AFJ
Post by AFJ » Mon Nov 02, 2020 3:55 pm
Hey there,
I have a noise and I want to add that noise to the audio tracks that I have in a folder. Can anyone please help me how to macro this all?
Re: Mixing one kind of Noise in multiple audio tracks
Post by steve » Mon Nov 02, 2020 4:12 pm
Are all of the files the same length?
AFJ
Post by AFJ » Mon Nov 02, 2020 4:14 pm
Not exactly, the difference might be in ms which can be neglected.
AFJ
Post by AFJ » Mon Nov 02, 2020 4:16 pm
The difference is in miliseconds, so we can say that the file lengths are the same.
Post by steve » Mon Nov 02, 2020 4:25 pm
In that case you just need the "Import2:" command to import the noise, followed by one of the Export commands (such as "ExportWav:").
For more information about Macros: https://manual.audacityteam.org/man/macros.html
AFJ
Post by AFJ » Mon Nov 02, 2020 4:30 pm
Import2 has parameters Filename=" ". I want to add the noise in 50 audio files, do I need to manually add these names?
Post by steve » Mon Nov 02, 2020 5:27 pm
No, you only need to use Import2 with the "noise" file. You will then apply the macro to batch process the 50 audio files.
AFJ
Post by AFJ » Wed Nov 04, 2020 10:23 am
Thank you so much!
