What is the best settings for reverb in Audacity? (For vocals/singing)
Re: What is the best settings for reverb in Audacity? (For vocals/singing)
Post by steve » Mon Nov 02, 2020 12:15 pm
jackplans wrote:
Mon Nov 02, 2020 11:57 am
That entirely depends on what sort of vocal reverb effect you want. I'd suggest that you start with either "Vocal I" or "Vocal II" factory preset ("Manage" button > Factory Presets") and adjust as required.
