Group tracks in Audacity 2.3.2
4l3xb34st
Post by 4l3xb34st » Sun Nov 01, 2020 5:36 pm
I work with Audacity 2.3.2
I've got two tracks that are basically 2 parts of the same verse.
Track 1
Track 2
What I want to do is to group them, so they make one track on one line.
Track 1-2
Re: Group tracks in Audacity 2.3.2
Post by steve » Sun Nov 01, 2020 5:43 pm
The current version of Audacity is 2.4.2. It is available via the Audacity website: https://www.audacityteam.org/download/windows/
Audacity doesn't have "track groups", but you can "mix" tracks: https://manual.audacityteam.org/man/tra ... u_mix.html
You can also change the waveform color of some of the tracks: https://manual.audacityteam.org/man/aud ... tml#colors
jademan
Forum Crew
Post by jademan » Mon Nov 02, 2020 1:30 pm
4l3xb34st,
I'm not sure exactly what you are looking for, but you could try "Select->All" (Ctrl-A), "Tracks->Align Tracks->Align End To End", then "Tracks->Mix->Mix And Render". Also, see this post:
viewtopic.php?p=407921
