Version 2.4.2, is it possible to locate the identical audio files in a section?
432
Post by 432 » Thu Oct 29, 2020 7:42 pm
Example:
If not, is there a safe program that allows me to scan and remove duplicate files, in terms of sound?
Trebor
Re: Version 2.4.2, is it possible to locate the identical audio files in a section?
Post by Trebor » Sat Nov 14, 2020 7:19 am
Audacity's spectrogram view could help you manually locate matching audio.
