de-clicker and de-esser
What is a de-clicker? I can't find it among effects. Also, I could use a de-esser, which I understand is a plug-in. Is it compatible with Audacity?
Re: de-clicker and de-esser
It's an effect that attempts to remove or reduce clicks.
I assume that you are referring to these plug-ins: viewtopic.php?p=245549#p245549
