How do I add a click or pop noise to an audio file
skrowten_hermit
Post by skrowten_hermit » Fri Oct 23, 2020 2:51 pm
I have an audio file of length 8 seconds and would like to modify it and add a few digital click or pop sounds to it. Can I do it with the help of audacity? If yes, how? Any help or pointers would be really helpful.
Re: How do I add a click or pop noise to an audio file
Post by steve » Fri Oct 23, 2020 2:58 pm
You could "draw" some clicks in the track. See https://manual.audacityteam.org/man/draw_tool.html
Trebor
Post by Trebor » Sat Oct 24, 2020 4:47 am
There is an Audacity plugin which can add crackle ... viewtopic.php?p=337525#p337525
