Limiter issue? Recorded files being capped?
Fingahz
Post by Fingahz » Tue Oct 20, 2020 8:58 am
Hello, does anyone know why my sound files being recorded are now capped and the waves not showing in full? This has happened before and I can’t remember what I did to rectify it? All I did was alter the recording volume top left a little, now my files aren't showing in full and have a flat top??
Trebor
Re: Limiter issue? Recorded files being capped?
Post by Trebor » Tue Oct 20, 2020 9:51 am
Sounds similar to this ... viewtopic.php?p=379317#p379317
Fingahz
Post by Fingahz » Tue Oct 20, 2020 10:23 am
Thank you, no it's not that. It's so strange as I know it's something simple but for the life of me I can't get it back to normal!!
Post by steve » Tue Oct 20, 2020 10:48 am
Perhaps we may be able to help if you give some details about your setup and what you are doing.
Almost certainly that is the result of "clipping".
"Clipping" occurs when an input signal exceeds the maximum available amplitude. For example it can occur when over-driving a microphone or amplifier. It can also occur in the digital domain by exceeding 0 dB anywhere in the signal chain. It can also occur as a result of poorly written device drivers incorrectly mixing or splitting audio channels.
Fingahz
Post by Fingahz » Tue Oct 20, 2020 11:13 am
Yes i've looked into all the clipping settings and can't find a solution, all i'm really using it for is recording my vinyl to mp3, and dj mixes to mp3, straight from my mixer, into the pc and audacity.
Post by steve » Tue Oct 20, 2020 12:56 pm
Does the recording sound distorted?
Are you able to monitor directly from the mixer? If so, does that sound distorted?
How is the mixer connected to the computer? If it's a USB mixer, what's the make / model? If it's not a USB mixer, what is the make / model of the sound card / audio interface that you are using?
Are you recording in mono or stereo?
Please post a short audio sample to demonstrate the problem. Just a few seconds in WAV format (see: viewtopic.php?f=49&t=72887)
(WAV format is important as some important clues about the problem can be hidden by lossy encoding).
Fingahz
Post by Fingahz » Tue Oct 20, 2020 1:02 pm
Recording is stereo. The audio is fine, that's not the issue. The issue is visually as now i'm seeing my files with a flat top and can't fully gauge when recording in, if i'm going to high to distort it. Hope this makes sense. I need to know how to stop it capping the files, they seem to still record ok, but they are all showing a flat top instead of the full wave.
Fingahz
Post by Fingahz » Wed Oct 21, 2020 8:35 am
No matter where I put the recording level too on Audacity, it still records with a flat top on the recorded file wave??
Post by steve » Wed Oct 21, 2020 11:48 am
Fingahz
Post by Fingahz » Fri Oct 23, 2020 11:30 am
How do I post up a sample? Sorry! Got one here..
