equalization
markjearl
equalization
Post by markjearl » Mon Oct 19, 2020 12:06 pm
I can't find Equalizer among the effects.
Re: equalization
Post by steve » Mon Oct 19, 2020 12:15 pm
In Audacity 2.4.2 there are two equalization effects:
Graphic EQ: https://manual.audacityteam.org/man/graphic_eq.html
Filter Curve EQ: https://manual.audacityteam.org/man/fil ... ve_eq.html
Erwa88
Re: equalization
Post by Erwa88 » Tue Oct 20, 2020 4:11 pm
Thank you !
I had the same question ! :D
