I was working in Audacity when the battery died on my computer. When I restarted the computer, Audacity had gone back to what looks like factory settings. All my plugins and keyboard stroke settings were gone. I have reinstalled multiple versions of Audacity, restarted my computer multiple times and tried to re-instal plugins to no avail. Oddly, my user presets in Amplify are still there but everything else is gone, including some of the pre-loaded effects, like Filter Curve. Gone. I tried to enable it in "add/remove plugins" and it won't come back.
I'm using Windows 10.
Back to Factory Settings and won't come back!
AnnemarieR
Re: Back to Factory Settings and won't come back!
It sounds like the Audacity settings files may have been partially corrupted due to the loss of power while open.
I think the best bet will be to fully reset Audacity back to factory defaults, then add back any customisations.
To reset Audacity, you need to shut down Audacity, then open (in the Windows File Manager) the hidden folder:
and delete the three files:
Code: Select all
C:\Users\<your user name>\Application Data\audacity\- audacity.cfg
- pluginregistry.cfg
- pluginsettings.cfg
waxcylinder
For future reference, once you have got you settings back to how you like them you may want to take a backup copy of the three files that Steve mentioned
And with the upcoming 3.0.0 you will be able to do the same with Macros (if you have any).
- audacity.cfg
