How to reverse and change speed in one effect
Winston
Re: How to reverse and change speed in one effect
Post by Winston » Tue Oct 13, 2020 12:36 pm
Tried this...
Code: Select all
;nyquist plug-in
;version 4
;type generate
;name "Convert from Stereo to 3 Channels..."
;action "Making extra channel..."
;info "This effect makes a temporary third channel from stereo"
(setf is-stereo (array p *track*))
     (aud-do "Duplicate:")
     (vector
       (snd-function (aref *track* 0))
       (snd-function (aref *track* 1))
     (snd-function *track*))
       (print "Track error.\nStereo track required. If you are trying to convert a mono file, use Convert from mono to 3 channels." else)))
...and "Print" didn't work...
...which is better, "print" or "throw 'err"?
Reason: code tags added
Post by steve » Tue Oct 13, 2020 1:02 pm
When you include code in your post, please use the "</>" button to create code tags. In the message editing widow they look like this:
[code][/code]
You then insert your code between the [code] and [/code]
like this:
[code]
Type or paste your code here
[/code]
The code tags ensure that the code formatting is preserved.
Post by steve » Tue Oct 13, 2020 1:38 pm
It depends what you want to do.
I'll write about PRINT here, then another post about THROW.
PRINT writes a string (text) to the default output stream - For Nyquist in Audacity the default output stream is the debug window. It also returns the string. Thus if a PRINT statement is the final line run, then the string will be returned to Audacity and Audacity will display it in a message window.
See: https://www.audacity-forum.de/download/ ... ef-200.htm
The PRINT statement can be useful when debugging code. For example this code fails:
Code: Select all
(setf data (list "A" "B" "C" "D"))
(setf myarray (make-array 4))
(setf count 1)
(dolist (val data)
  (setf (aref myarray count) val)
  (setf count (+ count 1)))
(print myarray)
The debug output is not particularly easy to understand
Code: Select all
error: index out of range - 4
Function: #<FSubr-SETF: #55555868d418>
Arguments:
  (AREF MYARRAY COUNT)
  VAL
Function: #<FSubr-DOLIST: #555558c6e088>
Arguments:
  (VAL DATA)
  (SETF (AREF MYARRAY COUNT) VAL)
  (SETF COUNT (+ COUNT 1))
... (more)...
To see what is happening within the DOLIST loop, we can add =https://www.audacity-forum.de/download ... 9.htmPRINC and PRINT statements like this:
Code: Select all
(setf count 1)
(dolist (val data)
  ; print some stuff to help debug
  (princ "Count is: ")
  (princ count)
  (princ " and val is: ")
  (print val)
  ; end of print statements
(print myarray)
The debug output is then:
Code: Select all
Count is: 1 and val is: "A"
Count is: 2 and val is: "B"
Count is: 3 and val is: "C"
Count is: 4 and val is: "D"
Function: #<FSubr-SETF: #555558681858>
Arguments:
  VAL
Function: #<FSubr-DOLIST: #555558687e78>
So we can see that the list is being stepped through correctly, but our "count" variable is wrong because =https://www.audacity-forum.de/download ... rt at zero.
We can then fix our code like this:
Code: Select all
(setf count 0)
(dolist (val data)
  (princ count)
  (print val)
(print myarray)
and see that it now works as expected.
After getting it working correctly, the diagnostic PRINT statements should be removed:
Code: Select all
(setf count 0)
(dolist (val data)
(print myarray)
Post by steve » Tue Oct 13, 2020 1:42 pm
Unlike PRINT, the THROW statement does not print anything. What it does is to stop the program immediately and send a message to it's associated CATCH.
See: https://www.audacity-forum.de/download/ ... ef-281.htm
and: https://www.audacity-forum.de/download/ ... ef-048.htm
Those pages include examples, so probably not worthwhile for me to add more examples here.
Post by steve » Tue Oct 13, 2020 1:49 pm
I'm not sure what you are hoping to do here, but it won't work.
Code: Select all
     (vector
Looking at the parentheses, the start of the function call is "(vector ...." and the end of that function call is the final ")"
VECTOR creates an array, and each argument is an element of the array.
You code is creating an array where the first element is (snd-function (aref *track* 0)), the second element is (snd-function (aref *track* 1)) and the final element is (snd-function *track*).
I suspect that you have miscounted the opening "(" and closing ")".
I would very highly recommend NOT relying on counting parentheses. Use a text editor that can highlight matching parentheses, such as NotePad++ (it's free).
Winston
Post by Winston » Thu Oct 15, 2020 6:42 am
Steve, about this...
Code: Select all
     (vector
...I'm trying to merge the duplicated stereo track to mono, without merging the other. I'm trying to duplicate both left and right channels, and merge them to make 1 stereo and 1 mono. 3 channels. Not to be mean, but if you made the program, how is this hard to understand? Basically, I want to copy a stereo track/channel to itself, and mix the copied track/channel without affecting the original. This...
Code: Select all
 ;nyquist plug-in
;version 4
;type generate
(setf count 1)
(dolist (val data)
  (princ count)
  (print val)
(setf count 0)
(dolist (val data)
  (princ count)
  (print val)
(setf count 0)
(dolist (val data)
(print myarray)
...doesn't work. It says that it "Nyquist returns value: 1". When I tried to debug, the error message came up, I think the part relevant to the problem is "error: index out of range - 4", because I believe it tried to duplicate 2 to 4, and remove 1 to 3, since it said "4" in part of the message, and "1" in the other, because 2+2=4-1=3. Options are to make one plugin that makes mono and stereo convert to 3 channels/tracks, or separate ones that only work for specified number of channels/tracks, which a message will come up if it isn't right.
Example of what I'm trying to do
Post by steve » Thu Oct 15, 2020 9:34 am
I didn't write the Nyquist programming language. Nyquist was developed at CMU.
Nyquist cannot add or remove Audacity tracks, or change a mono track to stereo, or change a stereo track to mono.
Nyquist can convert stereo audio to mono, but it can't change the Audacity tracks.
You can use Macro commands from Nyquist to add or remove tracks.
You cannot use Macro commands to change the Audacity tracks and Nyquist commands to change the audio in the same plug-in.
There are a few exceptions, but the basic rule is that you need to decide whether to use Macro commands or normal Nyquist commands in the plug-in, and don't attempt to mix the two.
Post by steve » Thu Oct 15, 2020 9:42 am
This...
Code: Select all
 ;nyquist plug-in
;version 4
;type generate
(setf count 1)
(dolist (val data)
  (princ count)
  (print val)
(setf count 0)
(dolist (val data)
  (princ count)
  (print val)
(setf count 0)
(dolist (val data)
(print myarray)
...doesn't work
If you change the code to this:
Code: Select all
;nyquist plug-in
;version 4
;type generate
(setf count 1)
(dolist (val data)
  (princ "Loop 1 -Count is: ")
  (princ count)
  (print val)
(setf count 0)
(dolist (val data)
  (princ "Loop 2 - Count is: ")
  (princ count)
  (print val)
(setf count 0)
(dolist (val data)
(print myarray)
Then you will see which DOLIST loop the error is occurring in.
Post by steve » Thu Oct 15, 2020 9:48 am
If you enable Advanced Mixing Options in Preferences, then this
will export as a three channel track.
(Multi-channel export is not available in Macros)
Winston
Post by Winston » Thu Oct 15, 2020 10:29 am
Accessed by: Edit > Preferences > Import Export (on a Mac Audacity > Preferences > Import Export )
The link you sent me is for "Mac", not "Win". I have Windows 10, So I'm assuming "Use custom mix" does the same as "Use Advanced Mixing Options"? Do I need a Macintosh emulator for Windows?
