Hello, I am trying to record my desktop audio on my Windows 10 device.
The sound is playing through my speakers just fine. I have checked and made sure that "Allow desktop apps to access your microphone" in Privacy settings is on. I have tried reinstalling audacity and am using 2.4.2. I have tried running audacity as administrator, I still gives the error.
Clicking on record button gives the following error:
Unanticipated host error
Error opening recording device. Error code: 0 Success.
Other settings:
Host: Windows WASAPI
Recording Channels - 2 (Stereo)
Project Rate: 44100 Hz
I am not sure why it has stopped working. I have been able to record just last month. Any help would be greatly appreciated
RoyalKnight
Re: Error opening recording device. Error code: 0 Success.
Are you using the computer's built-in sound card for recording and playback?
If so, check in the Windows Sound settings that the device is set for a sample rate of 44100 in the Recording AND Playback tabs.
Tony Burgess
- Operating System: Windows 8 or 8.1
RoyalKnight's problem is exactly the same as my own - I'm on Win8.1 Pro - ie the same error message.
I've read another thread along similar lines, tried uninstalling and re-installing 2.4.2, then 2.3.3 which I still had, then 2.1.3 which the person in the other thread found resolved the problem. All similar. And I was using Audacity 2.4.2 until a few months ago with no issues.
The speaker is playing fine, and I want to record something I'm playing on that. Used Audacity to do this for many years, so I don't understand the problem. Also I'm not as familiar with Win8 as I was with "good old XP".
So what to do? Audacity has been my go-to for many many years, and I'd like it to remain that way.
To get two present jobs done I'll try different software. But having not found a fix in over 2hrs of tyring I'm now appealing for help.
Also, I'm not sure that it would make any difference, but check that overdub and software playthrough are off.Tony Burgess wrote: ↑Wed Feb 03, 2021 2:25 pmThe speaker is playing fine, and I want to record something I'm playing on that. Used Audacity to do this for many years, so I don't understand the problem. Also I'm not as familiar with Win8 as I was with "good old XP".
if WASAPI fails, try MME.
I hope this helps.
