Error Message Bad Audio Data Length
rj7500
Post by rj7500 » Sat Aug 22, 2020 6:57 pm
Audacity 2.42
Windows 10
I downloaded a video file from YouTube, converted it to .mp3 and then attempted to use Audacity to edit it. When I imported the file the following error message appeared.............mp3 decoding failed...bad audio data length. Is this a function of You Tube downloads?
Thanks in advance for your help
Bob H
Re: Error Message Bad Audio Data Length
Post by kozikowski » Sat Aug 22, 2020 7:23 pm
Audacity 2.42
I suppose the first item is the version. The current version is 2.4.2. Versions from other makers may change the numbers around a bit. Those are different programs.
How? That step is the most likely to cause problems.
rj7500
Post by rj7500 » Sat Aug 22, 2020 9:22 pm
Sorry it's 2.4.2
Thanks for the help. I'm surprised because the mp3 will play on any of my audio players.
I guess we can close this out
