Mouse speed very slow in selecting recorded audio and recording is jumpy on the screen - any idea why?
Re: Mouse speed very slow in selecting recorded audio and recording is jumpy on the screen - any idea why?
Post by steve » Fri Aug 14, 2020 2:39 pm
Try reducing the number of colors in the "Compatibility" settings for Audacity.
Does that make any improvement?
happy37
Post by happy37 » Fri Aug 14, 2020 2:51 pm
Hi Steve,
How do I do that please?
Please advise.
Thanks.
happy37
Post by steve » Fri Aug 14, 2020 3:04 pm
Now you're asking - I rarely use Windows and I've not done this in years. If I recall correctly, you right click on the "audacity.exe" file in the "Programs" (32-bit Windows) or "Program Files (x86)" (64-bit Windows) folder, then click on the "Compatibility" tab. The option should be in there.... I think ;)
happy37
Post by happy37 » Fri Aug 14, 2020 3:16 pm
Done that Steve.
The mouse is still erratic and jumpy.
I'm out of ideas.
Thanks.
happy37
Post by steve » Fri Aug 14, 2020 3:55 pm
happy37 wrote:
Fri Aug 14, 2020 2:21 pm
Both machines are identical as they have the same processor.
The only difference is that the first machine has an Nvidia GT610 video card.
There's not much difference between the GT610 and GT710, so I doubt that is the problem, though drivers can make a significant difference. Perhaps worth checking if one machine is using newer drivers than the other.
happy37
Post by happy37 » Fri Aug 14, 2020 3:58 pm
Thanks Steve.
Will do.
happy37
happy37
Post by happy37 » Fri Aug 14, 2020 4:03 pm
Drivers are up to date Steve on this affected machine.
Thanks.
Post by steve » Fri Aug 14, 2020 4:31 pm
and on the "good" machine?
happy37
Post by happy37 » Fri Aug 14, 2020 4:36 pm
All up to date too Steve.
Makes no sense to me.
Post by steve » Fri Aug 14, 2020 4:39 pm
Yes, very strange.
Same mouse for both machines?
