Audacity 2.4.2, Windows 8.1, 64 bit
Recording device is "Speaker Headphone (Realtec audio loopback)
Recording channels: 2 stereo recording
Payback device: "Speaker Headphone (Realtec audio)
I am unable to adjust the recording level of songs. I tried various ways on my system but to no avail.
The horizontal bar on the microphone slide bar inside Audacity is fixed at extreme right side, and I am unable to reduce the level.
Can someone tell me what I need to do to adjust my mic level?
snoma01
Re: unable to adjust the recording level
If the show arrives at the system as a digital signal, then Audacity will let it all in on the assumption you wanted it to be that way. Sometimes you can change the recording volume in Windows control panels.
What's supposed to happen is you have volume controls on your microphone interface or sometimes on the microphone itself.
thank u for your comments.
I tried all of that in windows panel but to no avail.
There is no external mic as I use Windows recording system.
snoma01
snoma01
What does that mean? I'm not a Windows elf.I use Windows recording system.
When you select "loopback" you are accurately capturing the digital audio stream sent to your soundcard for playback so you can't change the volume.Recording device is "Speaker Headphone (Realtec audio loopback)
If it's "too loud" you can use the Amplify effect with a negative value after recording but that won't remove any clipping/distortion present in the original audio.and I am unable to reduce the level.
What he said. You change the analog volume of a capture system (see pictures above) to avoid noise and overload distortion, that's what the recording engineer does, but once the signal becomes digital, you're stuck. If the digital sound is so loud it overloads, the best you can do is change the volume of the overload distortion. The distortion is not going away.that won't remove any clipping/distortion
hello koz,
I meant recording system that comes as default with Windows 8.1 . I dont think there is a name for it.
as u have pointed out here, I am assuming the sound comes in as digital into my soundcard hence the recording level may not be able to be adjusted.
I will live with it, thank u.
snoma01
snoma01
