Windows 10 64 2.42 external DAC WASAPI Loopback no recording signal
SwellSound
Post by SwellSound » Sat Aug 08, 2020 6:31 pm
Hi All,
New user here with a new DAC> Topping D50s.
I've got everything set up and v2.42 see's the DAC with loopback enabled as pictured but when I record 44.1 digital, the cursor moves but no input audio/waveform appears. I've exported samples and played back with no audible signal.
So, I can play the source material through the DAC and hear it.
I can see the DAC in 2.42 but cannot get an waveform to appear or export/playback.
Anything obvious I'm missing here?
Thanks in advance for any insight you can share.
Kind regards,
Ron
Audacity 242 recording error.jpg (168.75 KiB) Viewed 369 times
