Windows 10 Audacity 2.4.2
Audacity records but the sound waves (wave track) do not display. No sound when playing back file.
-My Audacity settings MME, Microphone (2 High Definition) (Stereo) Recording Channel and Speakers (2 High Definition AU)
-The microphone and speaker sliding tabs are set to the maximum.
-In the Windows settings, allow apps to access the microphone and allow desktop apps to access the microphone turned on.
-When Audacity recording, the microphone symbol displays in the lower right hand corner that audacity is using the microphone.
-When I turn on the microphone and speak, the sound waves display? When recording from a website, NO -SOUND WAVES DISPLAY?
-Spatial sound is off?
-Windows Sound Settings output is speakers (2 High Definition Audio Device) input microphone (2 High Definition Audio Device)
Prior to yesterday, had no problems recording streaming. Sound waves displayed in Audacity.
Then, the sound waves stopped displaying? I uninstalled and re-installed Audacity.
I can hear the streaming with no problems.
Yet Audacity will not display the sound waves while recording. Thus no sound when playing back the recording.
Audacity Will Not Record Audio Streaming
Re: Audacity Will Not Record Audio Streaming
Choose WASAPI loopback. See this tutorial.My Audacity settings MME, Microphone (2 High Definition) (Stereo) Recording Channel and Speaker
