"Click Removal" effect pop-ups cannot be suppressed (makes macros not work well)
slycordinator
Post by slycordinator » Fri Jun 26, 2020 9:12 am
We have to record some narrated voiceovers for some online lessons at school, but with equipment not being great, I have to clean up the audio.
So, I made a macro that would first run the click removal effect then normalize the track to make the voice come out a bit louder.
This works fine except that occasionally, I'll have a file that the "click removal" responds with bringing up a pop-up that says that the effect doesn't work on that file and then can click okay. This stops the macro entirely; the rest of the steps never happen.
I worked around it by having a second macro that only does the normalizing step, but it would be preferable if it were possible to get that pop-up to be suppressed and allow the rest of the macro to continue.
slycordinator
Re: "Click Removal" effect pop-ups cannot be suppressed (makes macros not work well)
Post by slycordinator » Fri Jun 26, 2020 9:15 am
And if unclear, this is on audacity 2.4.1 on windows 10.
Post by steve » Fri Jun 26, 2020 9:36 am
It's not possible to suppress that warning, but you can probably trick the effect into not showing the warning by adding a second track containing a short audio clip that has an easily detected click. "Select All" then apply the effect. If you're running the Macro on a batch of files, you will obviously need to delete the second track prior to exporting.
