Timer record issue
Audacity V2.3.2, Win7 sp1, Acer 1815
Been using Transport - Timer Record successfully to capture 8 hour night noise over a week, I always record starting 2000(8pm) thru 0400.
There is a couple of minor issues with setting start time & date…
at about 1900(7pm) save project, setting up timer rec, the duration is preset to 8 hrs from previous timer records.
  1. When I click on the first digit in start time & press 2 it leaves a 0, until I click it again then its ok with pressing keys 2 0 0 0 0 0
  2. Now the start date has incremented by itself .
This does not occur if I set the timer earlier in the day (the end time is the same day)
Workaround is to remember to check start date.
Sometimes I forget if I’m tired & the record is 24 hours late.
Feature request: It would be nice to have a button on the next window so can return to timer settings to make a correction.
