Received my Blue Yeti today and plugged it in ............... aaarrgh ... I tried a short test"
- 5 secs of silence
- 2 min test recording
I got basically zilch. There was no sound track shown UNTIL I used the RMS normalize effect ... then got a track of sorts but not something with peaks and valleys as normally seen. So then I went through the entire drill to see what might happen: RMS normalize, Limiter, hum removal, ACX check (noise failed) ...... did the Noise effect on the silent section (which actually, for some reason, had a sound track) and then applied that across the board. Now noise passed ACX but the other two failed.
Not only that, I had no playback.
I'm open to any and all suggestions
BlueYeti Issue
Re: BlueYeti Issue
Disregard .... I fixed it
