Set the same volume to 16 mp3 files (newbie asking)
Gerardo
Post by Gerardo » Wed May 27, 2020 8:35 pm
Sorry. I know this has been asked before, but I know very little about Audacity and I would feel a lot more sure about trying out the solution if someone talks to me :oops:. I have used it a little bit before. Last year I removed the "emmmms..." from some voice recordings of interviews for example.
So I recorded my voice saying a speech in mp3. I now have 16 files; each one with one paragraph from the speech. I will eventually have to join them all together and it'll become the sound of a video. My problem is that the volume isn't the same on all the files. Can you please help me fix that?
On the forum, I read about normalizing and I also read about a plugin named "Chris's Dynamic Compressor plugin for Audacity". I also read something about "clipping"; don't know what that is. Do I have to install that plugin? Can you please help me with a step by step of what should I do?
Thank you very much in advance. So sorry for asking for a step by step I hope I won't be a newbie forever!
DVDdoug
Forum Crew
Re: Set the same volume to 16 mp3 files (newbie asking)
Post by DVDdoug » Wed May 27, 2020 8:49 pm
Try MP3Gain. If it works for you, it's fully-automatic and it works without decompressing/re-compressing the MP3 which can degrade audio quality.
And, you might want to use MP3DirectCut to join the files, because it also works without decompressing/recompressing. (I don't have a lot of experience with MP3DirectCut so I can't help you much with it.)
If that doesn't give you good results you can use Audacity (and we can help you) but when you open a compressed file in Audacity (or any "normal" audio editor) it gets decompressed. If you then re-export as MP3 you are going through another generation of lossy compression and with MP3 the "damage" does accumulate.
Regular normalizing adjusts the volume for a specific peak level (usually 0dB) but peaks don't correlate well with perceived loudness. There is now a "Loudness Normalization" effect built into Audacity.
That might help but I believe it was designed for music. Compression (and limiting) can make the quiet parts louder (or the loud parts quieter) whereas normalization makes the same adjustment to the whole file.
Clipping is distorted flat-topped waves that happen if you try to go over 0dB digitally, or if you try to get 110 Watts out of a 100 Watt amplifier, etc.
Your analog-to-digital converter (recording), your digital-to-analog converter (playback), and regular WAV files are all hard-limited to 0dB and you'll get clipping if you try to go over. Audacity itself can go over 0dB temporarily/internally and MP3 files can go over 0dB, but it's bad practice to make a MP3 that goes over 0dB because the DAC will clip if you play it at "full digital volume".
With loudness normalization or RMS normalization you can end-up pushing the peaks over 0dB so you have to "be careful".
Gerardo
Post by Gerardo » Fri May 29, 2020 11:11 am
Sweet! Thank you DVDdoug.
