2.4.1 track mix bug
2.4.1 track mix bug
Using win7 pro with 2.4.1. Found that when doing mix-down of multiple selected stereo tracks, the result shows only half the result to be selected as shown. Easy to fix but maybe indicative of an underlying problem?
- Attachments
- 2.4.1-mix bug.jpg (743.28 KiB) Viewed 89 times
Re: 2.4.1 track mix bug
Yes, it's a bug. It's on the Audacity bug tracker.
