Wherever bluetooth karaoke music-file is, just drag'n'drop a copy into Audacity.
Then sing along to it while it is playing in Audacity.
Then apply Grallion2 to the vocal track (only).
( You may have to time-shift the processed vocal track back a little so it is in sync-with the music).
Help with 'ghoul' voice effect
bluesjumper
Re: Help with 'ghoul' voice effect
Ahhh, I'm almost there..... When I record through my laptop mic (several year old HP EliteBook), everything works great. But when I record through my headset (cheapo Microsoft), no matter what I do, Audacity keeps starting the recording at the END of the song track. I definitely need to be able to sing to the music. So I'm wondering if there is an easy fix to this? And if not, I'll just record through the laptop mic. I assume recording quality is probably on par with the headset.
Tick "Record on a new track" in Audacity recording preferences ...bluesjumper wrote: ↑Sat May 09, 2020 10:38 pm... Audacity keeps starting the recording at the END of the song track ...
https://manual.audacityteam.org/man/rec ... ences.html
