SOUND TRACK
TJB
SOUND TRACK
Post by TJB » Fri Apr 24, 2020 3:48 pm
When I go back into the Master Edit file. the sound track is condensed .... how do I elongate it up to it's actual length which will enable me to find and delete a given section?
DVDdoug
Forum Crew
Re: SOUND TRACK
Post by DVDdoug » Fri Apr 24, 2020 4:21 pm
Do you mean visually? View -> Zoom.
TJB
Re: SOUND TRACK
Post by TJB » Fri Apr 24, 2020 5:21 pm
Perfect ... thanx
