opening error code 0
System was working fine up until today and now can't get into Audacity because of the error code 0 ... any help?
johnbailey32533
Re: opening error code 0
Same here. Can't get a handle on what happened nor how to fix. Most appreciative for any ideas
When and where does that error occur?
What exactly (and in full) does the error say?
