hello
running windows 7 with audacity latest version
tape deck line in to desktop for recording
when recording i notice the levels can be set and are influenced by both the volume slider and the recording level slider.
is this normal?
thanks
setting recording levels
Re: setting recording levels
my mistake....
i had the rec device selected as stereo mix by accident
changed to line in
problem resolved
changed to line in
problem resolved
