Probably missing something but the load preset button is greyed out to install an XML EQ file. Doesn't matter if I have audio in the project or not.
Any ideas?
Import EQ XML
waxcylinder
Re: Import EQ XML
It's grayed out because it's not available in 2.3.3
1) Import of EQ curves will be available im 2.4.0
2) the files will need to be in TXT format
3) 2.4.0 will have a tool for XML curves to TXT curves conversion
4) currently 2.4.0 is scheduled for 7th May
Re: Import EQ XML
Ok thanks buddy
