Can't access all 4 channels of Behringer UMC404hd
Snivonim
Post by Snivonim » Sun Feb 16, 2020 3:19 am
I am running Windows 10 and Audacity will only allow me access to two channels at a time.
Initially, before I installed the Behringer drivers, it looked like the WASAPI device was going to allow 4 channels, but when it tried to record it was erroring on the device.
So I installed the Behringer driver and then was able to record but only in groups of two channels at a time.
I specifically got a 4 channel mixer because I want to be able to record my drum kit and mic, snare, kick, toms and cymbals on separate channels. I have tried all different possibilities of combos of drivers and lower sampling rates etc.. but I am stumped on how to do this in Audacity.
Please help, or let me know if this is even possible. TY!
Re: Can't access all 4 channels of Behringer UMC404hd
Post by steve » Sun Feb 16, 2020 10:23 am
Please create an "Audio Device Info" text file, and attach it to your reply.
More info in these links:
https://manual.audacityteam.org/man/hel ... stics.html
viewtopic.php?f=49&t=64936
brownlow
Post by brownlow » Tue Feb 18, 2020 1:57 am
I have the exact same device and am having similar problem. Audacity not recognising input 3 or 4 on the UMC404HD. Going to follow here. Hope you get it fixed.
Post by steve » Tue Feb 18, 2020 9:23 am
See this post: viewtopic.php?p=387328#p387328
