Issues with 2.2.1
Jebbers
Operating System: Linux Mint
Issues with 2.2.1
Post by Jebbers » Thu Feb 13, 2020 1:37 am
This is the only version I can start. It's OK, but I'm having issues come up and need help. There's no joining of edits in a track. And the Clip Fix does nothing but de-amplify the selection. Am I going to have more troubles with effects and other functions?
Jebbers
Re: Issues with 2.2.1
Post by Jebbers » Thu Feb 13, 2020 1:53 am
Another problem is that the Mute and Solo buttons do not work independently. I can't solo two tracks at once with everything else muted.
Trebor
Post by Trebor » Thu Feb 13, 2020 2:29 am
There's an option to change how the mute/solo buttons work in Audacity preferences,
see ... https ://manual.audacityteam.org/man/tracks_behaviors_preferences.html
Jebbers
Post by Jebbers » Thu Feb 13, 2020 3:32 am
Thanx Trebor - That works. I selected Multi-track.
