Joining
Jebbers
Operating System: Linux Mint
Joining
Post by Jebbers » Thu Feb 13, 2020 12:33 am
I think I had a function called join in my other version. It joined the edits in a track. There was a shortcut like Shift+J. Now I'm running 2.2.1 and don't find that anywhere.
Re: Joining
Post by steve » Thu Feb 13, 2020 9:58 am
"Edit menu > Clip boundaries > Join".
The "Ctrl+J" shortcut is in the "Full" set of keyboard shortcuts. See: https://manual.audacityteam.org/man/key ... ences.html
Jebbers
Re: Joining
Post by Jebbers » Thu Feb 13, 2020 12:22 pm
Thanx Steve. OK, it's working now.
ctnvca
Re: Joining
Post by ctnvca » Sun Feb 16, 2020 1:42 am
Hi,new user////How do I join .FLAC tracks without degradation and data loss? Thank you.
Re: Joining
Post by steve » Sun Feb 16, 2020 10:12 am
1) Import the tracks
2) Join them
3) Export as FLAC
If you need it to be totally lossless, temporarily disable "dither" before exporting, and re-enable after exporting (see: https://manual.audacityteam.org/man/dither.html)
Formats higher than 24-bit cannot be saved losslessly with FLAC.
24-bit files must be saved as 24-bit FLAC to be totally lossless.
