Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
bigboss97
Post
by bigboss97 » Sun Mar 21, 2021 11:01 am
I took the loop from
pipeclient and added it to the old script. Now it works
Code: Select all
def do_command(command):
"""Send one command, and return the response."""
send_command(command)
reply=''
start = time.time()
while reply == '':
time.sleep(0.1) # allow time for reply
if time.time() - start > 5:
reply = 'PipeClient: Reply timed-out.'
else:
reply= get_response()
print(reply)
return reply
bigboss97
Post
by bigboss97 » Sun Mar 21, 2021 11:24 am
What does the '1' mean?
Code: Select all
[ 1,
[ 0, 0, "ccc" ],
[ 1.55871, 1.55871, "aa" ],
[ 3.26586, 3.26586, "Hello" ] ] ] ]
My understanding, there's no newline in labels. For my purpose (label2lrc), I want to have multiple lines. My idea is, allow user to add a label with special characters, e.g.'\n' Then the converter will make a new line. Does this make sense? or any better solution with Audacity?
- Site Admin
Post
by steve » Sun Mar 21, 2021 12:15 pm
bigboss97 wrote: ↑Sun Mar 21, 2021 11:24 am
Track index = 1.
The first track is index=0.
It is "possible" to put a newline in a label, but it is not officially supported and will create strange looking labels.
It is not safe to rely on multi-line labels as we don't know if they will work in the future or not.
- Second Track000.png (5.68 KiB) Viewed 293 times
bigboss97
Post
by bigboss97 » Mon Mar 22, 2021 9:59 am
Another question...
'SetLabel:' modifies existing labels. Is there a way to insert new label through pipe?
bigboss97
Post
by bigboss97 » Mon Mar 22, 2021 11:44 am
Thanks, this is exactly what I need.
Now I can Use
NewLabelTrack: to insert a new track, use
Select: to set the cursor and then
AddLabel:.
One thing I couldn't figure out, the number of tracks. I've to ensure that I'm selecting the right (last) track to add the labels.
I love the pipeclient. Now I can test the command one by one
- Site Admin
Post
by steve » Mon Mar 22, 2021 11:57 am
bigboss97 wrote: ↑Mon Mar 22, 2021 11:44 am
Super
That's precisely what I intended the command line interface to be used for.
bigboss97
Post
by bigboss97 » Mon Mar 22, 2021 9:59 pm
After NewLabelTrack:, I want to do a Select:. How do I find out what's the latest track number?
- Site Admin
Post
by steve » Mon Mar 22, 2021 10:03 pm
You can get the number of tracks and track types from "GetInfo: Type=Tracks".
bigboss97
Post
by bigboss97 » Wed Mar 24, 2021 11:13 am
Sorry Steve, I need your help again
I want to populate labels in a selected region. But I couldn't find any parameter in
GetInfo: to retrieve the start and end of the current selection.
