Convert Label text to LRC file
bigboss97
Re: Convert Label text to LRC file
Post by bigboss97 » Sat Mar 20, 2021 2:07 am
steve wrote:
Thu Mar 04, 2021 12:42 am
If you feel comfortable doing so, there's a "release candidate" for Audacity 3.0.0 available for testing. See: viewtopic.php?f=49&t=116221
I got RC6 portable. I haven't done that for such long that I'm not sure whether I've missed any step :lol:
I enabled mod-script-pipe, restarted and double checked enabled. When I ran my script I got nothing returned:
Code: Select all
PS E:\work\python\Audacity> python .\pipe_utf-8.py
pipe-test.py, running on windows
Write to  "\\.\pipe\ToSrvPipe"
Read from "\\.\pipe\FromSrvPipe"
-- Both pipes exist.  Good.
-- File to write to has been opened
-- File to read from has now been opened too
Send: >>>
GetInfo: Type=Labels Format=JSON"
 I read line:[
Rcvd: <<<
When I ran the same script on v2.3.3 I got:
Code: Select all
Send: >>>
 I read line:[[
 I read line:[  [ 0,
 I read line:[    [
 I read line:[      [ 0, 0, "Hello" ] ] ] ]
 I read line:[BatchCommand finished: OK
 I read line:[
Rcvd: <<<
  [ 0,
Another strange thing also happened. When I restart v3 mod-script-pipe is reset to New (after v3 has been launched).
The script:
Code: Select all
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import io
import os
import sys
if sys.platform == 'win32':
    print("pipe-test.py, running on windows")
    TONAME = '\\\\.\\pipe\\ToSrvPipe'
    FROMNAME = '\\\\.\\pipe\\FromSrvPipe'
    EOL = '\r\n\0'
else:
    print("pipe-test.py, running on linux or mac")
    TONAME = '/tmp/audacity_script_pipe.to.' + str(os.getuid())
    FROMNAME = '/tmp/audacity_script_pipe.from.' + str(os.getuid())
    EOL = '\n'
print("Write to  \"" + TONAME +"\"")
if not os.path.exists(TONAME):
    print(" ..does not exist.  Ensure Audacity is running with mod-script-pipe.")
    sys.exit()
print("Read from \"" + FROMNAME +"\"")
if not os.path.exists(FROMNAME):
    sys.exit()
print("-- Both pipes exist.  Good.")
TOFILE = open(TONAME, 'w')
print("-- File to write to has been opened")
#FROMFILE = open(FROMNAME, 'rt')
FROMFILE = io.open( FROMNAME,'r', encoding='utf8', newline='\n')
print("-- File to read from has now been opened too\r\n")
def send_command(command):
    """Send a single command."""
    print("Send: >>> \n"+command)
    TOFILE.write(command + EOL)
    TOFILE.flush()
def get_response():
    """Return the command response."""
    result = ''
    line = ''
    while line != '\n':
        result += line
        line = FROMFILE.readline()
        print(" I read line:["+line+"]")
    return result
def do_command(command):
    """Send one command, and return the response."""
    response = get_response()
    print("Rcvd: <<< \n" + response)
    return response
def quick_test():
    """Example list of commands."""
#    do_command('Help: Command=Help')
#    do_command('Help: Command="GetInfo"')
    do_command('GetInfo: Type=Labels Format=JSON"')
    #do_command('SetPreference: Name=GUI/Theme Value=classic Reload=1')
quick_test()
Post by steve » Sat Mar 20, 2021 11:33 am
Testing with Audacity 3.0.0 (release version) on Linux, when I send the command (from Python "pipeclient.py"):
Code: Select all
I get:
Code: Select all
Sending command: GetInfo: Type=Labels Format=JSON"
  [ 1,
      [ 0.435929, 0.435929, "hello" ],
      [ 2.13066, 3.33559, "world" ] ] ] ]
Now that Audacity 3.0.0 has been released, it's probably best to resume your Python work with the release version. See: https://www.audacityteam.org/download/windows/
bigboss97
Post by bigboss97 » Sat Mar 20, 2021 12:36 pm
Got the same result on v3 release. Do I have to do something under Extra menu which I've done on my v2?
Code: Select all
PS E:\work\python\Audacity> python.exe .\pipe_utf-8.py
Send: >>>
 I read line:[
Rcvd: <<<
Post by steve » Sat Mar 20, 2021 1:53 pm
Just ensure that "mod-script-pipe" is enabled in "Preferences > Modules".
(Note that Audacity has to be restarted after changing that setting)
Can you get any commands to work from Python? (for example, try sending "Play:")
bigboss97
Post by bigboss97 » Sat Mar 20, 2021 11:49 pm
"Play:" works, confirmed.
bigboss97
Post by bigboss97 » Sun Mar 21, 2021 12:08 am
Just tried:
do_command('SetLabel: Text=Hello LabelIndex=1 Start=2 End=3')
that works.
Post by steve » Sun Mar 21, 2021 12:19 am
Does
Code: Select all
work for you with "pipeclient.py" (command line interface)?
bigboss97
Post by bigboss97 » Sun Mar 21, 2021 12:46 am
Where can I find pipeclient.py?
Post by steve » Sun Mar 21, 2021 10:02 am
The same place as pipe_test.py. Here: https://github.com/audacity/audacity/tr ... piped-work
Documentation is in the file (See the Docstrings).
bigboss97
Post by bigboss97 » Sun Mar 21, 2021 10:32 am
Great! pipeclient works and the unicode issue has been resolved.
Now I have to update my old script for v3. Thank you so much for your very patient help.
Code: Select all
Enter command or 'Q' to quit: GetInfo: Type=Labels Format=JSON
  [ 1,
      [ 0, 0, "Hello" ],
      [ 1.31483, 1.31483, "小苹果" ] ] ] ]
