Convert Label text to LRC file
bigboss97
Re: Convert Label text to LRC file
Post by bigboss97 » Fri Mar 27, 2020 11:23 am
steve wrote:
Tue Mar 03, 2020 4:45 pm
I'll write back if I get more information. Sorry I couldn't be more help.
Any update?
Post by steve » Fri Mar 27, 2020 6:02 pm
Not as yet.
chenghuaiyu
plugin script of Converting Label text to SRT subtitle or mp3 LRC format
Post by chenghuaiyu » Wed Dec 23, 2020 2:36 pm
According this forum thread, I've learned a lot and written a plugin which convert label text to SRT subtitle or mp3 LRC format.following is the plugin script code.
Code: Select all
$nyquist plug-in
$version 4
$type tool analyze
$name (_ "Subtitle Generator")
$manpage "Subtitle_Generator"
$debugbutton disabled
$author (_ "Cheng Huaiyu")
$release 1.0.0
$copyright (_ "Released under terms of the GNU General Public License version 2")
;; http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
;; For information about writing and modifying Nyquist plug-ins:
;; https://wiki.audacityteam.org/wiki/Nyquist_Plug-ins_Reference
$control filename (_ "Export Label Track to File:") file (_ "Select a file") "*default*/subtitles" "SRT file|*.srt;*.SRT|LRC files|*.lrc;*.LRC" "save,overwrite"
;; Reurn number as string with at least 2 digits
(defun pad (num)
  (format nil "~a~a" (if (< num 10) "0" "") num)
;; Reurn number as string with at least 3 digits
(defun pad3 (num)
  (format nil "~a~a" (if (< num 10) "00" (if (< num 100) "0" "")) num)
;; Format time (seconds) as hh:mm:ss,xxx
(defun srt-time-format (sec)
  (let* ((seconds (truncate sec))
        (hh (truncate (/ seconds 3600)))
        (mm (truncate (/ (rem seconds 3600) 60)))
        (ss (rem seconds 60))
        (xxx (round (* (- sec seconds) 1000))))
    (format nil "~a:~a:~a,~a" (pad hh) (pad mm) (pad ss) (pad3 xxx))
;; Format time (seconds) as mm:ss.xx
(defun lrc-time-format (sec)
         (mm (truncate (/ seconds 60)))
         (xx (round (* (- sec seconds) 100))))
    (format nil "~a:~a.~a" (pad mm) (pad ss) (pad xx)))
; generate srt format subtitle
;;;;;; srt sample text:
;; 1
;; 00:00:00,260 --> 00:00:00,990
;; subtitle 1
;; 2
;; 00:00:02,220 --> 00:00:06,410
;; subtitle 2
(defun label-to-srt (labels)
  ;; subtitle index
  (let ((srt "")
        (ind 0))
    (dolist (label labels)
      (setq ind (1+ ind))
      (setf timeS (srt-time-format (first label)))
      (setf timeE (srt-time-format (second label)))
      (string-append srt (format nil "~a~%~a --> ~a~%~a~%~%" ind timeS timeE (third label)))
    (format nil srt)
;; generate mp3 lyric
;; [00:00.26] subtitle 1
;; [00:02.22] subtitle 2
(defun label-to-lrc (labels)
  (setf lrc "")
  (string-append lrc "[ar:Lyrics artist]\n"
                      "[al:Album where the song is from]\n"
                      "[ti:Lyrics (song) title]\n"
                      "[au:Creator of the Songtext]\n"
                      "[length:How long the song is]\n"
                      "[by:Creator of the LRC file]\n"
                      "[offset:+/- Overall timestamp adjustment in milliseconds, + shifts time up, - shifts down]\n"
                      "[re:The player or editor that created the LRC file]\n"
                      "[ve:version of program]\n\n"
    (setf timeS (lrc-time-format (first label)))
    ; (setf timeE (lrc-time-format (second label)))
    (string-append lrc (format nil "[~a] ~s~%" timeS (third label)))
  (format nil lrc)
;; Return file extension or empty string
(defun get-file-extension (fname)
  (let ((n (1- (length fname)))
        (ext ""))
    (do ((i n (1- i)))
        ((= i 0) ext)
      (when (char= (char fname i) #\.)
        (setf ext (subseq fname i))
        (return ext)
;; Get labels from first label track
(setf labels (second (first (aud-get-info "labels"))))
;;(setf txt (case file-ext (0 (string-append filename ".SRT") (label-to-srt labels))
;;                         (1 (string-append filename ".LRC") (label-to-lrc labels))
(setf file-ext (string-upcase (get-file-extension filename)))
;; detect file extension to determine which format to export
(setf txt (if (string= ".LRC" file-ext)
(setf fp (open filename :direction :output))
(format fp "~a" txt)
(close fp)
(format nil "~a" txt)
Given a filename, for example "SubtitleGenerator.ny", you can save the ".ny" file to the "Plug-Ins" subdirectory in your audacity location, or install it by "Tools" menu -> "Nyquist Plug-in Installer..." of the software,
Post by steve » Wed Dec 23, 2020 4:09 pm
Congratulations. That seems to work as intended.
Perhaps I could make a few suggestions. None of these affect the functioning of your script, but are more a matter of convention.
1. Headers
Code: Select all
$nyquist plug-in
$version 4
$type tool analyze
$release 1.0.0
Normally, headers begin with a semi-colon rather than a dollar sign.
(This may not be in the documentation yet)
Headers are treated by Nyquist as comments - they are ignored, but Audacity reads these special comments to convert the Nyquist code into a plug-in.
Comments normally begin with a semi-colon. However, the plug-ins that are shipped with Audacity use a modified form of these comments, with "$" instead of ";" so that shipped plug-ins can be translated into other languages. This translation mechanism does not work for third party plug-ins because the translations have to be compiled into the Audacity app.
The translatable strings are also enclosed in: (_ "translatable string")
For third party plug-ins, the the "(_ ...)" is ignored.
So the recommended way to write the above headers would be:
Code: Select all
;nyquist plug-in
;version 4
;type tool analyze
;name "Subtitle Generator"
;manpage "Subtitle_Generator"
;debugbutton disabled
;author "Cheng Huaiyu"
;release 1.0.0
;copyright "Released under terms of the GNU General Public License version 2"
In future versions of Audacity it "may" be possible to make third party plug-in headers translatable, but there's no guarantee that the syntax will be the same, so best to use the standard semicolon comment syntax.
2. Debug button
Until a plug-in has been available "In the wild" for a while, it's generally a good idea to leave the Debug button enabled. This is extremely helpful if anyone finds a bug. The debug button is enabled by default if you omit the header ";debugbutton disabled".
3. Manual page
The ";manpage" header creates a "?" help link in the interface IF there is a page in the manual with that name.
Example:
Code: Select all
;manpage ""Low-Pass Filter""
will take you to this page in the manual: https://manual.audacityteam.org/man/low ... ilter.html
For third party plug-ins (which are not documented in the manual), there is an alternative (and optional) way to include a help page. See: http://wiki.audacityteam.org/wiki/Nyqui ... s#helpfile
4. Trailing parentheses
The Nyquist language is a form of LISP. As with other forms of Lisp, it is conventional to avoid trailing parentheses. Thus:
Code: Select all
;; Good
            (label-to-srt labels)))
;; Bad
I hope you will find this useful for writing many more beautiful Nyquist plug-ins :-)
chenghuaiyu
Post by chenghuaiyu » Thu Dec 24, 2020 1:36 am
1. Headers
Code: Select all
$nyquist plug-in
$version 4
$type tool analyze
$release 1.0.0
Code: Select all
;nyquist plug-in
;version 4
;type tool analyze
;release 1.0.0
2. Debug button
3. Manual page
Example:
Code: Select all
Code: Select all
;; Good
;; Bad
Thanks a lot for your detail explanation.
Post by steve » Thu Dec 24, 2020 10:49 am
@chenghuaiyu
I'd like to suggest that you create a new topic for your Label to LRC plug-in so that it doesn't get lost in this long topic topic.
I'm a little concerned about the final line:
Code: Select all
If there's a lot of labels, this may create a window that is too tall, and Nyquist message text windows do not scroll.
How important do you think it is for the plug-in to display the contents of the file, rather than just a confirmation message that the file has been written? (There's several options of what could be done, but as I don't use LRC files I'm uncertain of what is important).
I'd like to see feedback from people that do use LRC files so that the plug-in may be tweaked if necessary prior to "publication". It isn't my decision for which plug-ins are shipped with Audacity, but if users of LRC files are happy with this plug-in, then I can upload it to Audacity's "official" plug-ins on the Audacity wiki (http://wiki.audacityteam.org/wiki/Downl ... t_Plug-ins).
bigboss97
Post by bigboss97 » Wed Mar 03, 2021 5:35 am
You're getting less on Windows than I do on Linux. Your version appears to be completely choking on the Unicode characters.
For the current version of Audacity, it appears that the script pipe module does not support Unicode at all on Windows. I've written to the developers about this, but I'm not hopeful of Unicode support being added any time soon, unless the problem was just an oversight that can be easily fixed.
Steve, have you got any update?
Post by steve » Wed Mar 03, 2021 9:30 am
I'm glad you reminded me :) In the release candidate for Audacity 3.0.0 (See: viewtopic.php?f=49&t=116221)
Nyquist still does not support Unicode (and probably never will).
Python scripting now correctly handles multi-byte characters returned from Audacity. (fixed)
bigboss97
Post by bigboss97 » Wed Mar 03, 2021 10:36 pm
[Python scripting now correctly handles multi-byte characters returned from Audacity. (fixed)
Super! Just can't wait to test that (continue my work at where I stopped). Oh that was even pre-pendamic.
The other day, I was thinking... I had started something with audacity and given up, but what was the reason?
Luckily, I bookmarked the thread. So I could read through my own thread again :lol:
Post by steve » Thu Mar 04, 2021 12:42 am
If you feel comfortable doing so, there's a "release candidate" for Audacity 3.0.0 available for testing. See: viewtopic.php?f=49&t=116221
