Convert Label text to LRC file
bigboss97
Re: Convert Label text to LRC file
Post by bigboss97 » Fri Feb 28, 2020 6:55 am
steve wrote:
Mon Feb 24, 2020 1:12 pm
You can get multi-byte characters from labels using "GetInfo: Type=Labels Format=JSON" via Python.
Thank you for your time.
This is my current results:
A) ASCII only (all good!)
Code: Select all
C:\tmp>python pipe_test.py
pipe-test.py, running on windows
Write to  "\\.\pipe\ToSrvPipe"
Read from "\\.\pipe\FromSrvPipe"
-- Both pipes exist.  Good.
-- File to write to has been opened
-- File to read from has now been opened too
Send: >>>
Rcvd: <<<
  [ 0,
      [ 1.52091, 2.31039, "hello" ],
      [ 3.47138, 3.47138, "world" ] ] ] ]
BatchCommand finished: OK
B) Unicode
Exported labels:
Code: Select all
1.520907	2.310385	hello
3.471383	3.471383	小苹果
Piped:
Code: Select all
Rcvd: <<<
  [ 0,
    c:\wxwidgets-3.1.1\include\wx\strvarBatchCommand finished: OK
I know that my Windows/DOS shell doesn't display unicode characters. But it should at least show me some unreadable characters :roll: :?:
Post by steve » Fri Feb 28, 2020 11:20 am
The scripts provided by Audacity assume that data is plain ASCII, and will not work with multi-byte Unicode characters. With Python3 you will probably see errors like:
Code: Select all
"UnicodeDecodeError: 'utf-8' codec can't decode bytes in position x-y: invalid continuation byte
I should have said that "I think it should be possible to get ..."
The "GetInfo: Type=Labels" can definitely handle multi-byte Unicode characters
(try it from Audacity's "Extra menu > Scriptables II > Get Info").
I "assume" that Python3 is capable of accessing that data, but you would need to write your own Unicode compatible functions to read and write Unicode data to/from Audacity.
bigboss97
Post by bigboss97 » Fri Feb 28, 2020 12:40 pm
It took a while until I found where to activate the Extra-menu :-)
Yes, that works. I can write a Python script to read the JSON output. But how do I pipe that output to my script?
Post by steve » Fri Feb 28, 2020 1:24 pm
If you can get Python to read the Unicode labels, then you should be able to the whole thing with Python.
bigboss97
Post by bigboss97 » Sat Feb 29, 2020 3:08 am
With my limited Python skill and Google's help :lol: , I tested the UTF-8 read/write:
Code: Select all
import io
encoding = 'utf8'
with io.open('utf-8.txt', 'r', encoding=encoding, newline='\n') as fin:
    text= fin.read()
    print( text)
with io.open('utf-8_out.txt', 'w', encoding=encoding, newline='\n') as fout:
    fout.write(text)
then I modified the pipe_test.py:
Code: Select all
FROMFILE = io.open( FROMNAME,'r', encoding='utf8', newline='\n')
*snip*
    while line != '\n':
        result += line
        line = FROMFILE.readline()
        print(" I read line:["+line+"]")
    return result
I guess I can leave TOFILE as it is.
This is my output:
Code: Select all
 I read line:[[
 I read line:[  [ 0,
 I read line:[    [
 I read line:[      [ 0, 0, "Hello" ],
 I read line:[    c:\wxwidgets-3.1.1\include\wx\strvararg.BatchCommand finished: OK
 I read line:[
Rcvd: <<<
  [ 0,
      [ 0, 0, "Hello" ],
Is Audacity writing an UTF-8 pipe?
mod-script-pipe is a DLL. I couldn't look into it.
Post by steve » Sat Feb 29, 2020 11:53 am
Does it work for you with just a single label:
Code: Select all
bigboss97
Post by bigboss97 » Sat Feb 29, 2020 12:31 pm
No, it shows one path. Basically it shows a path whenever it's unicode. For instance:
Code: Select all
0.359909	0.359909	Hello
2.159456	2.159456	回頭我也
4.040272	4.040272	world
6.315828	6.315828	不要你
Code: Select all
 I read line:[      [ 0.359909, 0.359909, "Hello" ],
 I read line:[    c:\wxwidgets-3.1.1\include\wx\st      [ 4.04027, 4.04027, "world" ],
 I read line:[    c:\wxwidgets-3.1.1\include\wx\strvarBatchCommand finished: OK
My UTF-8 routine failed totally when I tried with German:
Code: Select all
1.253878	1.253878	Lüneburg
Code: Select all
 I read line:[[
Traceback (most recent call last):
  File "pipe_utf-8.py", line 82, in <module>
    quick_test()
  File "pipe_utf-8.py", line 79, in quick_test
    do_command('GetInfo: Type=Labels Format=JSON"')
  File "pipe_utf-8.py", line 71, in do_command
    response = get_response()
  File "pipe_utf-8.py", line 64, in get_response
  File "C:\Users\home\AppData\Local\Programs\Python\Python37\lib\codecs.py", line 322, in decode
    (result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xfc in position 42: invalid start byte
Post by steve » Sat Feb 29, 2020 1:25 pm
Which version of Python are you using?
Post by steve » Sat Feb 29, 2020 1:54 pm
On Linux, with Python 3, this will read the return message and print as hex values. You may notice that with two labels containing "小苹果", the printed data is a mix of UTF-8 and non-UTF-8 (UTF-8 and "latin 1" characters perhaps?).
Code: Select all
import os
import sys
PIPE_BASE = '/tmp/audacity_script_pipe.'
WRITE_NAME = PIPE_BASE + 'to.' + str(os.getuid())
READ_NAME = PIPE_BASE + 'from.' + str(os.getuid())
EOL = '\n'
write_pipe = open(WRITE_NAME, 'w')
read_pipe = open(READ_NAME, 'rb')
def send_command(command):
    """Send a single command."""
    print("Send: >>> \n"+command)
    write_pipe.write(command + EOL)
    write_pipe.flush()
def get_response():
    """Return the command response."""
    result = ''
    line = ''
    last = ''
    while (last != b'\n' or line != b'\n'):
        #result += line
        last = line
        line = read_pipe.read(1)
        print(line.hex(), end=' ')
send_command("GetInfo: Type=Labels")
get_response()
bigboss97
Post by bigboss97 » Sun Mar 01, 2020 11:53 am
Python 3.7.5 on Windows 10
Audacity 2.3.3
