RX7 AS A PLUG IN
wuhan_87
RX7 AS A PLUG IN
Post by wuhan_87 » Sun Feb 02, 2020 5:06 pm
Hey people,
Is it possible to use RX7 as a plug in in Audacity? If so how do I go about doing this?
I want to refrain from copying my file into RX7 and then bringing it back again. If I can access RX7 as a plug in Audacity this would save me an extra step!
Thanks in advance!
Re: RX7 AS A PLUG IN
Post by steve » Sun Feb 02, 2020 11:01 pm
According to the iZotope website: https://www.izotope.com/en/products/rx.html
Supported Hosts:
Audition CC 2018, Ableton Live 9–10, Cubase 9.5, Digital Performer 9, Final Cut Pro X*, FL Studio 12, Logic Pro X, Nuendo 8, Premiere Pro CC 2018, Pro Tools 10–12, Reaper 5, Reason 10, Studio One 3–4
*RX 7 is intended to be used as Final Cut Pro X’s default audio editor. For instructions on doing so, click here.
